Baxi bermuda G.F. Super Gas fire
Ian Ollerenshaw
Member Posts: 4
Andy, Thanks for your reply and advice.
Yes it is a flat plate as you suggest! and the flame around the t'couple is smaller than the rest of the plate, so maybe the t'couple is just not getting hot enough although it is in the flame!. i shall also try DIYnot.com
Cheers Ian
Cheers Ian
Baxi burmuda G.F. Super Gas fire
Hi, hope someone can help,
I have a Baxi Bermuda G.F. Super Gas fire which i can not get to light.
The pilot will ignite OK but i cannot get the main burner on.
I thought i needed to replace the Thermocouple which i have done, but still cannot get it to fire up. not sure what to do next??
Thanks in anticipation, Ian0 -
Hi Ian
This site is used by American and Canadian Heating engineers. You will be best visiting DIYnot.com.
By the way the burner on that type of fire is like a flat plate with small drillings for the flames. The holes around the thermocouple are probably blocked. I would suggest getting it serviced.
Cheers Andy.
Ian
Ian, this site is used by American and Canadian heating engineers, sure, but that is the least of it. Homeowners, contractors, installers and designers and others of all stripes and from many countries find a place here. Stick around if you are so inclined. Some may be able to help. Maybe not.
Cheers,
Brad0 -
Not familliar with
your peticular heater but those units all use saftey switches to prevent startup if an unsafe condition is present. It would be wise to contact a professional familliar with ths type of unit.0 -
Thanks Bruce, i think i will get it serviced! just thought if it was a t'couple, it would be easy to replace myself!
Cheers
ian0 -
Brad, Thanks for your reply and warm welcome.
Cheers Ian0
- 167 Indoor-Air Quality
