cv / feet of head
ralman
Member Posts: 231
The feet of head loss for a cast iron baseboard is very low compared to the pipe and fittings.
I'm trying to establish a true head loss on my system so I can put the right pump in. Some of the system components' paperwork gives cv values. Anybody know how I can convert this number to head loss in feet of head?
Thanks.0 -
head loss
head loss in feet = (1.52*gpm/Cv)^2
-Andrew0 -
Does that formula work for cast iron baseboard?
A manufacturer's chart lists an 8' CIBB at 2.68 pressure drop in inches of water at 2000 lbs/hr(4 GPM) flow rate. I was trying to convert to feet of head. Is 2.68 X 2.31 = 6.19 A correct method for figuring the feet of head?0 -
loss
Just divide 2.68 by 12 to get 0.22 ft of head
-Andrew0 -
Thanks, just what I was looking for.
Izzy0 -
IZZY
B&G has a very nice "System Syser Calculator" that can be obtained from their web sight. I think you would love it. Would answer all of your questions.
Mike T.0
- 87K THE MAIN WALL
- 113 Chimneys & Flues
- 106 Geothermal
- 981 Plumbing
- 388 Solar
