Radiator floor escutcheons ornate variety
Hi all,
If anyone is looking for antique 'anything' having to do with plumbing, hardware, home stuff, etc, this is a great place to start:
http://historichouseparts.com/default.htm
Also here:http://www.robinsonsantiques.com/
Regards,
Howard
  • Radiator floor escutcheons of the ornate variety
    Is anyone familiar with a good place to purchase radiator floor escutcheons of the ornate variety either on-line or in my local area? I'm in Seattle WA. I need the split type of escutcheon as my system has just been upgraded to a Buderus GB 142 and has also just been re-filled with water so I don't want to drain the system again, then remove the pipes to then install the non-split escutcheons if that makes any sense.
    I'm including a pic of my current escutcheons that I'd like to duplicate, reason I need them is some of them are missing.
    Thanks for the help!
  • That original doesn't look split. Am I missing something?
  • escutcheons
    I know it doesn't, and when I took the picture I didn't realize it was split either, but as I was removing it I saw the seems. This is the same one that I removed, and it's definitely split!
  • Mark Hunt
    Mark Hunt Member Posts: 4,908
    I can't help you but
    I have a customer that would also love a source for the same thing.
    I'll keep looking and if I find something I'll let you know.
    I would appreciate it if you forward any helpful info that you may find.
    TIA.
    Mark H
  • Will you post an "open" photo from the under side?
    As mentioned many would LOVE to find such a nice escutcheon--I won't even mention splitted...
  • Patrick North
    Patrick North Member Posts: 84
    Pipe escutcheon replicas
    Try here:
    http://www.vandykes.com/product/02005732/
    Usually pricey, but they carry good quality stuff.
    Patrick North
