Radiant Mixing Q
lekpeter
Member Posts: 35
The slab's max temp is 85 degrees and that would work for the bathrooms as well.
Radiant Mixing Question
My current system Budereus 124, indirect DHW, with staple-up radiant on first floor and radiant concrete basement slab, both using injection mixing controlled by a pair Tekmar 356s.
My upstairs baths (under construction) have radiant tubes embedded in a mortared base under tiled floors. Are you guys aware of a piping/control scheme that would allow me to use the existing concrete slab's injection pump and 356 controller to also control supply water to the bathrooms?
I'd like to avoid buying another injection circ. and Tekmar 356 controller if I can.
Thanks
lek0 -
Temperatures
What is the design temperature in the basement radiant loop? What is the design temperature of the bathroom loop?0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 946 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
