pe charts
Eugene Silberstein 3
Member Posts: 1,380
Scroll down (or up) for charts!
pe charts
I took professor silberstein's class on pressure enthalphy. I finished reading through most of the book and would like to start plotting some charts. does anyone know where to get some blank charts. never thought to ask that while I was at the class. thankyou0 -
P.E. Charts
Remember that each refrigerant has is own P.E. chart!0 -
Here you Go!
Here are charts for R-134a, R-407c and R-410a. Be careful as the information for R-407c and R-410a contains metric pressure enthalpy charts as well!
I do not have R-22 in a pdf, but I will e-mail it to you.
Enjoy.0 -
You Have Mail
You have mail Dennis.0 -
Hope this helps.
I think the scanner should print clearly.
Mike T.0 -
Scaners
My scanner works fine,,,,,,,as long as I use a magnifying glass!!0 -
...0 -
How is the Plotting Going?
Keep us posted on how the plotting is going.0
