Toe kick heater (hydrate) /Steam System
ed wallace
Member Posts: 1,612
best done thru a side arm tankless or flat plat heat exchanger that way the toe spave heater is under 12 psi and no chance of flashing to steam
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=354&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Toe Kick Heater (hydrate) On Steam System
What is the result of installing a toe kick heater (hydrate) on a steam system?
Can it be done?
What is the downside?
Will it damage the pipes?
Will it upset the flow of the system?0
- 167 Indoor-Air Quality
