Paul Mueller Refriferation
ddlong1286@yahoo.com
Member Posts: 139
Hi all,
Anyone work on Paul Mueller milk coolers? I am working on one that the control board sparks and goes dead. Checked the cooling relay-ok. Am going to bench test some pcb's that may have only blown a fuse on the board.
Thanks
Don in MO
Thanks
Don in MO
Don! Hi!
Bulk Milk Coolers. Worked on them back in 72'-79'. The control panel has changed over the years I'm sure.Tell me more!!!!0 -
Sounds interesting...
Never worked on one but, just as Randy said... "Tell us More!"0 -
HiPerForm
Sorry it has taken so long, kinday busy.
It is a model AWS727 HiPerForm. Haven't needed to touch the refrigeration side just the control panel. Went back Fri and found a grounded wire that I replaced. Got a call today and found a bad fuse, wire inside looked good but no continuity. Replaced and everything worked ok. We had bad storms that Fri nite and am guessing that may have been todays problem. They are going to use it tomorrow morn and I will know then.
E-mailed P. Mueller about training got nothing back.
Also noticed that they use Westinghouse patent, not sure if for the controls, refrigeration or everything?
Don in MO0
