hepex install in rough enviroment
Tim Doran
Member Posts: 208
What sort of stuff is in the area? Call me on Monday mornignto discuss. 631-537-5767 (o) or 612-865-6059 (c)
Tim D.
Tim D.
hepex install in rough eniviroment
Wondering if any one knows the chemical resisentance of wisbro hepex in commerical application .Was planning to use some on a job where flamable compounds are present and used in the production of there final product but i am unsure if this may cause pre mature tubing failure or may be a bad idea .Thanks for any input most of the job will most likely be screwed or groved pipe .Peace and good luck clammyR.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
Specializing in steam and hydronic heating0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
