Baseboard problem
Brad White_79
Member Posts: 11
If it is not broken, don't fix it.
Bright side: The velocity increase means the next room heats just a wee bit faster! (Just kidding.)
The baseboard heating in my livingroom goes through a wall and then starts up again. I just happen to notice that who ever installed the baseboard went from a 3/4 in copper pipe to a 1/2 in pipe to go through the wall then back to the 3/4in. I never noticed this before.
What problems could this cause? Should I bother to remove the 1/2 in pipe and go 3/4 all the way through?
Thanks0 -
how does it heat?
are you experiancing any problems?
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"gwgillplumbingandheating.com
baseboard problem
No I dont think there have been any problems. But could this cause efficency problems?0 -
Be ok
If its heating ok do not go looking for problems. J.Lockard0
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
