L8148A1124 differential
Thanks Carol. I'll add the L8148A1124 to my list of aquastats with a differential of 15 degrees.
  • Ron Schroeder
    Ron Schroeder Member Posts: 995
    Hi Carol,
    What is the high limit differential for the L8148A1124? I have found the differential for about 6 other versions of the L8148A but not this one.
    Thanks,
    Ron
  • carol_3
    carol_3 Member Posts: 397
    The only one I have info on is the A1017, which is 8 degrees. Is yours an OEM model?
  • Ron Schroeder
    Hi Carol,
    Yes it came with a boiler but I have seen them on several boiler brands with the same full model number. I have seen at least 6 different types L8148's. The specs that I have seen are either 8 degrees or 15 degrees depending on the last 4 numbers. I just need to know what this version is.
    Thanks,
    Ron
  • carol_3
    This one's 15 degrees.
  • carol_3
    Ron, would you email me at carol.fey@honeywell.com. I'd like to get more info from you about what you know about all these controllers.
