mixing valve question
Mike C_3
Mike C_3 Member Posts: 62
I can't find any info on this unit. It's not a job we did just something we have to service.
  • Brad White_9
    Brad White_9 Member Posts: 2,440
    Might be
    that it is calling for heat and may be either modulating in that direction or is at it's maximum position and still calling. Do you mean the "+" or "-" light? Does it never stop?
    My Honeywell Centra set-up was similar but at the control panel: Plus to Minus when modulating and red plus green when holding steady.
    Just my guess from here.
  • DWood
    DWood Member Posts: 60
    I think
    Brad's got it right ... which ever red light is flashing is the direction of rotation ... I think this unit was distributed by Paxxon if you can find their local representative to confim.
    Good Luck
    DWood
  • Mike C_3
    ok next thought
    can anyone find some info on this? on how to set it and all. the HO had some problems and played with everything.
  • Ragu_4
    Ragu_4 Member Posts: 44
    Mike C
    That unit is a Paxton VSE-1. The newer version is a VSE-2 with digital readout. Alan California Radiant Forbes has posted here about them and has used them; I haven't yet.
    Paxton Corp.
    Shelton, Ct.
    203-929-1800
    www.paxtoncorp.com
