mixing valve question
Mike C_3
Member Posts: 62
I can't find any info on this unit. It's not a job we did just something we have to service.
Might be
that it is calling for heat and may be either modulating in that direction or is at it's maximum position and still calling. Do you mean the "+" or "-" light? Does it never stop?
My Honeywell Centra set-up was similar but at the control panel: Plus to Minus when modulating and red plus green when holding steady.
Just my guess from here.
I think
Brad's got it right ... which ever red light is flashing is the direction of rotation ... I think this unit was distributed by Paxxon if you can find their local representative to confim.
Good Luck
DWood0 -
ok next thought
can anyone find some info on this? on how to set it and all. the HO had some problems and played with everything.0 -
Mike C
That unit is a Paxton VSE-1. The newer version is a VSE-2 with digital readout. Alan California Radiant Forbes has posted here about them and has used them; I haven't yet.
Paxton Corp.
Shelton, Ct.
203-929-1800
www.paxtoncorp.com
- 167 Indoor-Air Quality
