dangerous boiler
Steamhead (in transit)
Member Posts: 6,689
the flueways plugged up?
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=367&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
dangerous boiler
service call today very old hydro therm boiler millivolt system with a separate pilot light before gas valve tenant complaining about high gas usage land lord called gas company about problem gas company says usage normal will not send out a tech I get there smell something funny checked for CO found 22 ppm at boiler removed top cover of boiler flames between jacket and cast iron time for a new boiler
dangerous boiler
no flue ways were not plugged the smoke pipe and chimney had no obstuctions i turned the unit off at the gas valve and unwired it am in proscess of installing a new boiler only thing i can think of that might have caused the problem is the gas jets being fowled or bad millivolt gas valve
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
