Merchant coupling usage..........
singh
singh Member Posts: 866
Early in my career I once worked on a job that we ran over 300' of 4" overhead gas pipe and we used those couplings,boss thought he was saving a few bucks, every single one leaked under test.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=377&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • Seattle Nick
    Seattle Nick Member Posts: 64
    ....what good are they anyway? I did find this quote on Eng-Tips:
    "Merchant couplings are thread protectors, and nothing more. They're installed on one end of mill threaded pipe to protect the threads from damage during shipping. I don't know of any pressure piping code that permits them to be used in service. They are to be removed and discarded."
    I tend to agree with that statement, but am I missing
    something? Would a professional use a merchant on a 2" galvanized water line between the main and the meter?
    No big deal? What do you think? Should I trust the other forty feet of pipe we can't see?
    AnthraciteEnergetics
    EBEBRATT-Ed Member Posts: 18,448
    Many may not agree with me but I have done the research. 2" and down throw them out they are only thread protectors.
    2 1/2" and up you can use them they are perfectly good. The reason is 2" and under do not have tapered threads they have straight threads. 2 1/2" and up come with tapered threads.
    I convinced a tough gas inspector on this and showed him and he acepted this.
    ED
  • Seattle Nick
  • Bill Hobbie_2
    Bill Hobbie_2 Member Posts: 4
    NICE JOB ED.
    Bill Hobbie
  • Tony Conner_2
    Tony Conner_2 Member Posts: 443
    Thread Protectors
    People need to look at the code requirements for their particluar installation. Depending upon what you're doing, the installation could fall under:
    1/ plumbing
    2/ sprinker/fire protection
    3/ fuel utilization
    4/ ASME pressure piping codes (there are several of these)
    People need to know the codes for what it is they're working on. Lots of different grades of fittings: 125/250 cast iron, 150/300 malleable, 2,000/3,000/6,000 forged steel, etc.
    Toss the mechant coupling/thread protectors in the scrap bin unless you know for a fact that they're ASME registered fittings.
  • bob young
    bob young Member Posts: 2,177
    banded couplings
    believe it or not ,we used those couplings all the time until fairly recently and with minimum problems. water piping we always used wick & compound so no problem there ,gas another story but always used permatex &it usually held the mewrcury test. we didn't know any better although the code stated " banded fittings" we never even gave it a thought. sometimes ignorance is bliss !over thirty years 'till we figured it out ! what a ride !
