over heat boiler
Jim_79
Jim_79 Member Posts: 1
Had new radiator valves installed and an over flow tank. Boiler is overheating and turning off before the radiators get hot.
  • Big Ed
    Big Ed Member Posts: 1,117
    No flow
    Did you put water back into the boiler? do you have enough water pressure on the system? Left valves shut off ? Did you bleed the radiators?Do it again...
  • Brad White_9
    Brad White_9 Member Posts: 2,440
    Is there a bypass?
    There may be a bypass between supply and return, playing catch with your flow in the system at the expense of proper flow through your boiler...
