dwyer manometer
ed wallace
ed wallace Member Posts: 1,612
I went to thier web site 3 times and 3 timesw was told i am not authorized to view the pages can anyone help me get a users manual for my very expensive paper wieght
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=354&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • ed wallace
    dwyer manometer
    I just bought a dwyer manometer in order to test gas pressure on a gas valve well to my suprise there is no owners manual with it and tech support is beyond useless can anybody provide a users manual or did i just spend $275.00 on a nifty paper wieght yes i checked there web site sent them nan email and followed it up with a phone call to no avail
  • Brad White_29
    Brad White_29 Member Posts: 5
    Is it the Series 477 Ed?
    Mine did not have instructions either beyond the generic how to use a pitot tube pamphlet. I found it pretty straight-forward. Turn it on, zero it and off you go. The catalog may have more information than that. Surprised that you find nothing.
    Let me know or contact me off-line if you like.
    Brad
  • Ron Schroeder
    Ron Schroeder Member Posts: 995
    You should read
    "Measurement of Pressure with the Manometer" in our catalog
    https://www.dwyer-inst.com/htdocs/literature.cfm
  • ed wallace
    dwyer
    I got no paperwork with the manometer then when i try looking up literture on thier web site it tells me i need permission to view it why the heck does a company sell a digital instriment and provide no instuction sheet i have the model 475-1 digital manometer only instuctions on use are on the card backing the plastic display package
  • Ron Schroeder
    Ed
    I know what you mean it just makes no sense to sell something without documentation, they say on the facts page to review info in thier catalog, was you able to load the page I sent, it has the catalogs and a place to submit your name and address
  • Kevin O. Pulver
    Kevin O. Pulver Member Posts: 380
    I agree
    You can't even buy a lousy toaster without a manual to help you enjoy the full potential of the thing.
    I shelled out $600 or so for a Rothenberger tee puller, and NOTHING. I'm impressed, but not in the way they hoped. Kevin
  • ed wallace
    mark
    I tried that link all it gives me is the same info i got with the meter there has to be more information on using the manometer i will travel up to 100 miles from boston ma in order to use this tool can anybody help an idiot learn to use a manometer
  • Greg_34
    Greg_34 Member Posts: 19
    Gas Line Pressure
    Hi,
    I just read your post regarding the Manometer. This instrument is used to test pressure of air within a moving body (ie, ventilation sytems, exhaust stacks, etc.)
    I don't think you are using the right tool for your application.
    I've got some instructions for the use of a pitot tube and manometer that I could post which will show how to measure the velocity pressure and subsequently find cfms. (need to make them .pdfs) However, as far as wanting to know the pressure in a gas feed line, unless you want to test how quickly the gas is moving, this isn't the right tool. It works amazingly well if you're attempting to understand the volume of air being drafted to the chimney.
    Cheers,
    Greg
    Greg
  • Brad White_9
    Brad White_9 Member Posts: 2,440
    It will measure
    any gas within it's pressure range, moving or not. It is a total pressure gauge and that includes velocity, static and total pressures.
  • Brad White_9
    Here is the attachment I sent
    last night to you, Ed. On page two are the operating instructions.
    Anyone else care to take a look and see if I am missing something? Seems pretty straightforward to me. I would cut and paste the text but it is an Adobe PDF file so you just have to open it and read it. Too lazy to type I suppose.
    Nothing to it, just zero the gauge before taking a reading.
  • Bob Eh?_2
    Bob Eh?_2 Member Posts: 42
    For what you want to do just zero the guage connect the high presure port to the test port on the burner assembly or meter (Adapters often required) and read the pressure....
    Bob
  • Greg_34
    OK
  • Greg_34
    OK
    So, he'll just need an adapter, and not use the pitot tube. When I looked at the equipment on Dwyer's site, I knew using a pitot tube wasn't an option.
    thanks for the heads up.
    -Greg
  • Mark Hunt
    Mark Hunt Member Posts: 4,908
    You beat me to it.
    I was just about to post that link.
    Ed, could you be more specific about what you want to know?
    Mark H
  • ed wallace
    dwyer meter
    ok call me a freeking idiot if you want to but those directions are no help at all what do i need to do to hook up to a gas valve it really would be nice if dwyer would include written directions on how to use this manometer heck i have neber ever bought a test meter of any sort that did not have some sort of manual that explains how to use it heck most have drawings that show how to use
  • bob_50
    bob_50 Member Posts: 306
    Digital manometer
    Ed, I hope you didn't buy that fancy digital manometer just to check gas pressures. All that's required is a couple of feet of small diameter hose or tubing an adapter a bucket of water and a ruler. Connect the tubing to the gas, stick the other end in the water, turn on the gas and pull the tube up until it just starts to bubble. Measure how much tube is below the surface of the water and that's the pressure in inches water. Cheap and more accurate than a digital. bob
  • Ron Schroeder
    Ed
    I am less han fifty miles north of Boston e-mail me I am sure I can get you headed in the right direction. I use a U-tube myself.
  • HI ED
    I have the same meter on my truck. Only thing you need to measure gas pressure iis a chunck of tubing and the barb connector that goes in hte outlet pressure tapping of the valve. Remember to plug the negative pressure port as I believe it can effect the final readings. I especially like the meter to check the negative gas pressures on W/M GV boilers(-.2" WC). It really pegged a couple for me.
    The biggest complaint that I have is that it seems extremely tempermental in low teemperatures. IT IS NOT the meter to get of the truck in 0 degree temps and expect to be accurate. Once it warms up, however, it seems to be ok. Also, when the battery gets low, it hunts without warning. I wish the instructions were more accurate also but what do you do. Good Luck. Hope this helps.
  • will smith_4
    will smith_4 Member Posts: 259
    Gas pressure Test
    I've been using the Dwyer 0-5" and the Dwyer 0-10" magnehelic forever. No batteries, easy to calibrate, checks positive/negative pressures. Along with a Ritchie 0-20 0z guage, you're set-all three for less than one digital.
