over heat boiler
Jim_79
Member Posts: 1
Had new radiator valves installed and an over flow tank. Boiler is overheating and turning off before the radiators get hot.
No flow
Did you put water back into the boiler? do you have enough water pressure on the system? Left valves shut off ? Did you bleed the radiators?Do it again...0 -
Is there a bypass?
There may be a bypass between supply and return, playing catch with your flow in the system at the expense of proper flow through your boiler...0
- 167 Indoor-Air Quality
