Stapler for radiant plates
Steve_35
Member Posts: 545
for the light weight aluminum transfer plates? We're going to do a radiant ceiling soon and I want to get something other than a T-50 for this.
electric
They make an electric version of the T50.
For extruded plates I have a Spotnails 1/2" crown framing stapler that eats 5/8 - 2" staples. I'll never use screws again
Extruded or??
Extruded plates, even the "lite" versions available would need more than a hand stapler.
Also the floor to which you intend to staple may decide the proper tool
The new AdvanTech and Plytanium subfloors products are VERY hard to shoot a nail into! I've noticed more mis-fires with these products compared to the softer wafer board products.
I have these choices below for production work. This is Senco middle weight stapler. Their lighter version may work for flashing gauge plates?
Around here the box stores rent equipment like that, but they may not have the short 3/4" staples or coil nails in stock.
hot rod
These are the very light weight aluminum plates.
I don't know the thickness but if I had to guess I'd say 0.020"...0.025" max.
Oh, and we're going into furring strips on the ceiling joists.0 -
I wonder that
those swing hammer staplers might handle that? A little tough on the arm if you have miles to install
Here is a piece of .040 aluminim sign material I slammed with this Bostich.
They also make a gun to shoot those button nail for roofing felt, as shown in the pic. Probably not too many around for cheap, however.
hot rod
anyone ever tried glue?
I thought about trying different types of contact cement to see if it would work; to get better contact. It would suck if they fell off though.0 -
I would think
That glue would hinder the heat transfer. My stapler makes extruded plates tighter than screws, IMO. I've done 'em both ways, and I'll stick with staples.0 -
What model stapler do you have, Tony?
> For
Old Thread
This thread was more geared toward extruded plates, but I think a pneumatic tool would be good for sheet metal plates also.
Old Thread
-Andrew0 -
Spotnails XS6650
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 999 Plumbing
- 391 Solar
- 55 Water Quality
- 45 Industry Classes
