How to unfreeze isolation flanges
D107
D107 Member Posts: 1,911
They are slotted shutoff valves on either side of our Taco 007s; probably used due to low ceiling height instead of ball valves. usually exercise them once a year but last time they wouldn't budge. Penetrating oil?
Thanks,
David
  • EricAune
    EricAune Member Posts: 432
    They can be tough!
    Another great reason to use anything but a set of Grundfos iso valves. I have had luck with the right sized screw driver and only when the system is hot.
    Get the boiler up to temp(dial up the limit if it is a mod/con and runs at a low temp).
    Good luck & peace
    hot_rod Member Posts: 25,124
    some of those
    actually have a recessed hex down in that screwdriver slot. That is a better tool to use. Tap around them with two hammers. One as backup, a small ballpeen hammer to jar things loose.
    P-oil may help also, if it can get to the ball.
    Even the handle type iso flanges can seize after time. I have snapped the brass stem on those also, trying to free them.
    Heck, even ball valves on water lines seize up.
    Notice the better quality ball valves have larger diameter stems, maybe better quality brass, also. Seems like the import valves, regardless of the brand name on them, barely hold the nut to keep the handles on, anymore. The stems are so small and flimsy.
    hr
  • Big Ed_4
    Big Ed_4 Member Posts: 3,211
    Just My Luck
    Everytime I try to shut off one of those combo flange shutoffs they break or leak. Either they snap or the o ring tears. I have not tried the newer models because I been scared off. I just drop the pressure and try to hold a vacuum ..
