Single Valve Purge
EricAune
Member Posts: 432
I might have missed that part too. I really like these valves though. You get primary/secondary with isolation all in one. I have been using them for about two years, they really make for a nice install given the time saved purging. Their iso/drain pump flanges are great too.
http://www.blueridgecompany.com/radiant/hydronic/672/webstone-valves
Peace
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=589&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Peace
Single Valve Purge
Page 48 in Dan's book "Pumping Away" shows a single boiler drain to purge a multiple zone system. Makes a lot of sense.
Page 85 shows the same thing on a primary/secondary loop system. I don't see how this would work. Won't the water just flow straight through the closely spaced tees? It seems an isolation valve between the tees would be necessary to get water to flow through the zones or have I missed something?0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 946 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
