Turning Boiler Off During Summer Time
Resnick_3
Member Posts: 2
When turning your boiler off for the summer should you:
Note: In my case I have a gas boiler with a standard pilot
1. Turn the boiler power switch off and turn the pilot knob to off?
or
2. Turn the boiler power switch off and turn the gas valve off?
I'm wondering which way is better/correct.
or
Turn the valve off, if you have a damp basement, I wouldn't shut it off unless you have a dehumidifier.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 55 Water Quality
- 48 Industry Classes
