Baseboard radiators with buily in return lines
jeff_51
jeff_51 Member Posts: 545
used to hang underneath, I think everything else sits on top now
  • KenMez_2
    KenMez_2 Member Posts: 8
    Baseboard radiators with built in ruturns
    I am looking for brands of baseboard radiators that have return lines built into them. I have two rooms in my house that are on a slab and would like to eliminate the line that runs underneath the slab that connects the two rooms. I have seen radiant baseboards that have the two lines built into them already,are they rated to handle 180 degree boiler water?I have learned a great deal reading The Wall over the past couple of years but have never seen this topic discussed.
  • steve b_10
    steve b_10 Member Posts: 1
    > discussed.
  • ChasMan
    ChasMan Member Posts: 474
    I have this stuff. Its from Slant Fin. I run 180 water in it and it ticks and pops a lot but thats what they call charm in these parts. Its basically just regular finn tube in a bigger housing.
  • KenMez_2
    Chas, what style slant-fin is it?
  • Brian_18
    Brian_18 Member Posts: 94
    Sterling Petite-7
    I have Sterling Petite-7 baseboard, which I did exactly what you want. They don't have "built in" return, but are set up to use optional wire hangers to support a 3/4 pipe above the fin tube. A standard return elbow connects the end of the fin tube & the 3/4 return pipe.
    http://www.sterlingheat.com/html/petite.htm
  • ChasMan
    Dunno.. It looks like Baseline.. Its cheap and nasty. The return runs underneath the fintube.
  • Rodney Summers
    Rodney Summers Member Posts: 748
    any sterling or argo brands
    offer a return pipe hanger that can carry tubing back over the finned element. Dont think you can do it underneath.
  • Phil_6
    Phil_6 Member Posts: 210
    slant fin
    has room to lay the return pipe right on top of the element. An elbow and a street ell and back you go
  • KenMez_2
    Thanks for all the good info ( I knew I came to the right place)I'm checking out the Sterling site now.
