Connecting all grounds on SR506
superMARKet
Member Posts: 87
Connecting grounds on SR506
There will be 6 ground wires in my SR506 once I'm done wiring the 120 stuff. How do people connect them all? I was thinking of screwing in a ground bus bar to the box. I don't like the idea of one big honking wire nut.
thanks,
jim0 -
One way you describe
This is what I normally do. I have used bus bars as well. After all six are run, I will usually throw a zip tie around all of them to keep it tight and uniform looking.
Biggerstaffradiantsolutions.com
sounds good to me too.0 -
bus bar
I ended up using the bus bar. It was easy and looks fine. Thanks for your input...
jim0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 989 Plumbing
- 389 Solar
