heat gain program
Thanks for the link!
  • bill phillips sr_2
    bill phillips sr_2 Member Posts: 10
    heat gain program
    What is the best heat gain program available in terms of accuracy and ease of use? Thanks.
  • JackFre
    JackFre Member Posts: 225
    Can't say if it is...
    the best, but if you go to the "contractor log-in" section of www.fujitsugeneral.com thereis a free program for your use. username is "installer". password is "1ton12kbtu". Hope it is helpful. You can also open all specs, install, operation, service manuals for each model.
  • Eugene Silberstein 3
    Eugene Silberstein 3 Member Posts: 1,380
    As the guys here...
    As the guys here on the Wall are well aware, I am a big fan of Manual J. It is definitely NOT the easiest to use, but, as an educator, my take on the situation is, that, if you can understand Manual J and where the information is coming from, there is no heat gain/heat loss method that you will not be able to work with.
    I teach my students Manual J for this reason.
