Caleffi.
Ted_9
Member Posts: 1,718
Im having trouble getting their radiant manifolds to seal. I wish they had specific instructions with the product.
When will some company give us Americans real lessons on connecting european fittings.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=373&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
What different products
does everyone use from them? And what is your experience +or-.0 -
Caleffi
We use their fill valves,air eliminators, and auto air vents, which by the way comes with a small check to let you change them with out draining the system.
Caleffi is a good product at a fair price.0 -
Sepcoll - Hydrolink
Zoning by circulator with outdoor-reset. It's a thing of beauty.
Regards,
PR
Biggerstaffradiantsolutions.com
I really like
their fill valves, HydroLinks, and zone valves. They have some rather unique hydronic components.
hot rod
We use alot
of the Hydro seperators and Hydro link. Very innovative company.0 -
Caleffi products
they have all kinds of goodies:) there are electrical and computer lash ups too,...parts also
like clean machine work , they have sensors for rooms slabs out door ,I would say that the Quality is There and the company has pride in its workmanship.
if you like erie zone valves you will definitely like the caleffi,they have fill valves the old ones were sorta er...different ,air bleeders ,seperators , and some smart pieces. i would recommend any of the products .0 -
fast fill
The auto-feed/backflow prevent is a great product. You can set the psi to 28 when filling and purging a system and walk away to a remote manifold secure in the knowledge that the pressure relief valve will never blow off.0 -
New Products
Caleffi is introducing several new products for 2006. They are adding manifolds without valves, new zone valves, a pump/mixing valve assembly for connection to the hydrolink, as well as an expanded line of solar components.
Caleffi is a great company with great people. Their products are all top qulality. It is a pleasure to do business with them.
-Andrew0 -
where do I find them
Does anyone have a link for them??
Mason
bump
just put a 2" calafii air seperator on a system. have not filled it yet but compared to a spirovent which i would normally use 1/2 the price and much smaller.
Zones valves. Good price. Good CV rating. We use them a lot.
Dave in DenverThere was an error rendering this rich post.
Loctite
Use Loctite 638 or 620.
-Andrew0
- 167 Indoor-Air Quality
