advise of a good wood boiler.thanks,john in PA
hr
Member Posts: 6,106
The OWF outdoor wood furnace is generally a open un-pressurized tank style, Basically a drum in a drum with a camp fire inside. Central, Woodmaster Hardy, Heatmor, HeatSource, Taylor are a few of dozen's of brands.
A few manufactures offer pressurized versions, Aquatherm, and Royall. Both of these are available as unsheltered version also. Royall is one of the few I have found with ASME if that matters in your area.
All the above run 28- 45% efficiencies.
I prefer gasification boilers that recycle the flue gas and extract addition energy, similar to a condensing boiler concept. These have tested in the mid to high 80% efficiencies. Tarm is the best know name around here.
I also install several brands of Euro gasification units sold at www.newhorizcorp.com. Gasification boilers have smaller fire boxes and lower water content and almost require a buffer tank to smooth out the operation.
I believe Greenwood out of Washington is a US built, and another new gasification in Maine somewhere.
It takes a bit of piping and $$'s to install one correctly. To tie it in with a gas or oil fired back up gets more involved also.
I don't believe Burnham offers the Woodlander anymore?
hot rod
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
hot rod
wood boiler
Advise of wood boiler sources and contact info.I'm a contractor in western Pa. Does Burnham still make one?
Thanks, John Helsel in Avella.0 -
My choice, helsel....
H.S.Tarm. U.S. headquarters in Lyme, New Hampshire.
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 999 Plumbing
- 391 Solar
- 55 Water Quality
- 45 Industry Classes
