plumbing question
Larry (from OSHA)
Member Posts: 742
Ok, I finally got around to dealing with this. The winning method was the angle grinder with the cutoff wheel. Went through very easily. A couple smacks with a hammer and chisel took care of the rest.
Thanks for all the advice.
Larry
Larry
this seems to be futile
4 inch vertical cleanout most likely has not been opened since 1962. The city is requiring an inspection for leaks that could impact ground water, etc. prior to next years road/sewer construction project. I've been beating on this with wrench and sledge and the location does not lend itself to getting a long breaker bar on it. So how do you deal with these? I wanted to exhaust my DIY efforts, and I think I have. Your expertise is appreciated greatly.
Larry0 -
I feel your pain, Larry.
You may want to give up on trying to salvage the cleanout cap. Drill it out, and use channel locks, vice grips, dynamite, or anything else appropriate to completely remove it. Buy yourself a new cap, preferably with a raised square "wrench lug" on it.
Starch0 -
those things....
can be a pain in the hemi's...If its a 4" pipe and its brass drill out the center w/ a hole saw, then use a dollar plug to cap it back off...kpc
Cleanout
Definatly drill a hole in the center then use a sawzall to cut the cap into 1/4 sections and pop the pieces right out then get another brass plug with a raised head to replace it.0 -
When you replace it...
I like to lube em up with "never-sieze" and then just tighten it gently. It doesn't need to be pipe wrench tight.
May aid in getting it out in the future.
Good luck,
JimThere was an error rendering this rich post.
I agree with the drilling advice
First get a couple black iron plugs with heads that will fit into the holes in your plug. Use a pipe wrench to grab a plug and see if you can twist out your in floor plug. If the pipe plugs don't help you time for the drill.
Leo0 -
I'm with
the drill it and then cut it out group, Larry.
I still have half a dozen different sized threaded lead plugs that I used to use in similar situations although I'm not sure if they are still made.
Good luck,
Jack0 -
quick job
> Starch
take a cold chisel & lump hammer & smack it two or three times and cave in thread. . it will pop right out & then replace with new plug or fit-all plug. should take ten or fifteen minutes.0 -
Thanks
I really appreciate the advice. I never really thought I'd be able to save the cap. Just anything to get this bad boy out!
Bob, maybe 10 to 15 minutes for you, but for me, easier said than done.
I think that I'll go for the drill and saw route.
Larry0 -
Don't forget the safety glasses, ear protection, long sleeve shirt, gloves, hard hat & steel toe boots!!
TimJust a guy running some pipes.0 -
Victory at last!!
take that ya knuckle buster.
- 167 Indoor-Air Quality
