mm. lwco question ?
RonWHC
Member Posts: 232
on the 67 is used for 120 volts, 24 volts, or millivolts.
lwco question?
if i replace a series 67-g mm float style lwco. with a new series 67 mm float style lwco. should be no problem? or are the contacts different with, millivolt system. tom0
- 62 Biomass
