snow melt
Tom Bradd
Tom Bradd Member Posts: 34
Hi folks.I have a snow melt system in my house. just a side walk. two loops 5/8 3" underfoam styrofoam. Simple system switch on the wall. there is a strap on aquastat,set for 60F is that ok or should I crank it to 120 or higher. There is a Heat exchanger 80 percent glyclo it says. Thanks in Advance.
JIM
  • Contractor
    Contractor Member Posts: 41
    You have water with a 80% gloycol mix or should i say you have glycol with a 20 % water mix? :D
    if that strue that seems mighty mighty high.
