new boiler Hamilton engineering
schiller
Member Posts: 60
Has any one installed a boiler from "Hamilton engineering"
its call an EVO Micro, if so what are your thoughts or if you have serviced them what did you think?
thanks
troy
thanks
troy
Hamilton boilers
Usually the Hamilton boilers I have seen are actually sourced out from Lochinvar. Exact same boiler with a different sign on it. Tim0 -
EVO
We have installed a couple dozen. They work great. They can be common vented. I have 2-630MBH boiler and a 136MBH boiler all vented through a 6" pvc pipe. And they all are wall hung. Sweet setup. If I could figure out how to post pictures I would or will. Hamilton actually makes this boiler it is theirs.0
- 110 Chimneys & Flues
- 978 Plumbing
- 387 Solar
- 17 Recall Announcements
