Taco RMB-1 problem
info...what is it doing? or not doing? What is the application..radiant floor...slab or staple up...how many btu on the zone(s)What is the temp outside when working.....etc...kpc
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=323&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • burninben
    burninben Member Posts: 33
    I have a Taco RMB that is not working properly, anyone have any experiences w/ them
  • burninben
    Well Kevin, its one of those I shouldn't have done it jobs. Guy wants to sve money, do some of it himself, not use enough valves, pumps etc. I'm sure you've had them. Anyway my question is- do I need to have anything hooked up to the boiler molex connector? He has a corn(barn) burner that some guy sold him and it is wired closed on the TT so I have a primary loop that is always hot. so do i need to lie to the control so it thinks it is turning the boiler on and off.
  • Phil_6
    Phil_6 Member Posts: 210
    RMB
    No
  • same dealership?
    I have a saleman trying to sell this owner a outside corn boiler... He said the twin tubing underground pipings can carry 178,000 btu thru the 3/4 id no problem..
  • Joe Mattiello
    Joe Mattiello Member Posts: 748
    I can try to help you, if you want to give me a call at 401-942-8000, X 484.
    Joe Mattiello
    Taco Comfort Solutions
  • Joe Mattiello
    Joe Mattiello
