Ripple Effect!
Techman
Member Posts: 2,143
Hi! I used Polmolive liquid soap as a lube, on the job today and less ripples .I'll try something else, thanks!
Ripple Effect!
Morning!Professor! A question on Tube Benders!I use a set of 4-piece gear tube benders ,nice tools.Recently I purchased a different kind of bender set.It looks like a "crossbow",pull the click lever and bend ! Now on a 90* bend there are "ripples" on the inner bend.Is this a problem ? or a "don't worry "! This was on 7/8 and 3/4 OD copper,soft.Enjoy Your Day!0 -
If I may.......
The ripples should not pose a problem, but if you want to rid them, Use a-little penetrating oil.. The tube is binding up.. Try it and let me know what you think... Actually,..Spit will work to......no joke;-)
Mike T.0 -
Just as Mike Said....
The ripples will pose absolutely no problem.0 -
Ripple!(wine)
HI! I'll try the lubricant,the shoe is a plastic of some kind, my thanks!I will let you know how it works out.0
- 123 Chimneys & Flues
