Wireless stats
Ray Landry_3
Member Posts: 94
Hey guys, I've got an install we did last year where I need to microzone a radiant floor zone. I want to power telestats via a wireless stat due to the p.i.t.a factor involved in getting new wires to the space. I've heard bad things about them though, garage door openers turning on the heat, ect. Any good luck with them? If so what kind? How would you control the load side of your telestats? Use the wireless stat through a switching relay and power your zone valve heads through 24vac?
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=463&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Wireless
Ive had good luck with the Totaline brand stats. No known problems. I'm not sure of the rating of the contacts inside the reciever, I guess it would depend on how many telestats you were powering.0
- 167 Indoor-Air Quality
