piping question
Al Letellier_9
Al Letellier_9 Member Posts: 929
It kind of depends on where they are in the loop and what the capacity is of the sunray. How will the BTU takeout effect the rest of the loop. I usually install two mono tees to help with flow...do some of the math to determine the best way to pipe them up.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=522&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • Robert O'Connor_12
    Robert O'Connor_12 Member Posts: 728
    Piping question
    I'm currently installing 2 baseboard systems in series loop configurations. My question/problem is the customer wants to re-use two existing sunrads that are installed in the bathrooms (1 sunrad ec., per loop). Can I leave out 3/4"x1/2" monoflo tees to pick them up and if so, should I use 2 of them or just 1 on the supply (or return) and, which direction should I feed the loop meaning the sunrad in the beginning or end of the curcuit. Thanks!
  • bob young
    bob young Member Posts: 2,177
    separate radiation
    you might consider piping the sunrads independently.
