where can you buy new cast iron radiators
K HAYNES
Member Posts: 10
I HOPE YOUR CLIENTS ARE WEALTHY BECAUSE THIS COULD BE A COSTLY VENTURE
I am working on an old home that has a hot water heating system with cast iron radiators. The home froze this winter, splitting 7 of the 10 radiators. I am trying to find new radiators to match what was existing which are similar to Burnham's classic style radiators. Is there any other manufacturer that still makes this type of radiator?0 -
Governale
might have some offerings.
http://www.governaleindustries.com/VictoriaRadLit-Gov.pdf
These look suspiciously like the Burnham Classic line so I surmise that one makes them OEM for the other.
If you are in MA, Fran Fahey at A-1 in Somerville would be my first call.
(That is the http://www.antiqueplumbingandradiators.com/ link that Steve gave by the way. I did not recognize it at first.)0 -
where ara you located.can you post pictures0
- 120 Geothermal
