giacomini actuators
ALH_4
Member Posts: 1,790
I am not completely positive, but I believe Oventrop's manifolds and compression assemblies are metric as sold in the US. AFAIK, most manifolds are imported and adapted from metric, so all you would need to convert them back are the metric compression assemblies.
giacomini
Does anyone know where to find Giacomini actuators. I beleive it is earlt generation "in-floor". I would consider changing out the manifold but it is euro pipe measure in millimeters.0 -
watch the pin length
easy enough to find actuators with the right thrad. You need to watch the dimensions so it is not partially opened when you screw it on. there are some spacers available for switching brands and models if needed.
Hi-Valley in Colorado has purchased Infloor they could probably help.
mwillburn@hi-valley.com
hrBob "hot rod" Rohr
Living the hydronic dream0
- 167 Indoor-Air Quality
