Radiator Heating top to bottom
Jim Ward
Jim Ward Member Posts: 7
Is it normal for a radiator to only be hot/warm at the very top or, should the entire coil be hot? I understand that they will not necessarily heat all the way across, unless it's the coldest day, and wonder if the same applies vertically.
