Can the McDonnell Miller 67W-2 LWCO be serviced?
Steve Garson_6
Member Posts: 35
I have a WM SGO-4. The low voltage switch on the McDonnell Miller LWCO is intermittent and powering the water feeder when it doesn't need water. I have connected an ohmmeter to the switch terminals and see that it is closing and opening even though the water level is fine. The high voltage part of the switch is fine.
I can't see any way to open this device to replace the switch. Is this designed to be repaired, or disposed of?
I think.....
I may have a few of those switches. It can be replaced.0 -
Thanks. It was defective from a month after installation and I finally decided I should do something about it. The LWCO is OK, though:0)0 -
mcdonnell miller 67
hi steve to bad you didnt tell the installer about the faulty 67 when it 1st acted up could have gotten it replaced under warrentee0 -
can do
replacement swiches have always been available. much easier than replacing unit & cheaper by far , too.0 -
#11 switch0 -
Ed:
Yeah, I know. But I really didn't care. Nor did I want to waste the time of the installer since it wasn't his fault. I just figured I would deal with it one day, eventually.
Steve0
- 85.7K THE MAIN WALL
- 50 Biomass
- 74 Chimneys & Flues
- 93 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 854 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.6K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 87 Job Opportunities
- 15 Recall Announcements
