TT ODR & Indirect
if you attended the TT training course in Blackwood you would have them,,, email me & I`ll steer you to someone who knows.<BR>For some reason, these are closely guarded secrets.<BR><BR>Dave
ODR & indirect on TT 110
Have a newly installed TT 110, now I hope to install the ODR and indirect Smart 40 this weekend. Are there any specific changes I need to make at the boiler control, such as parameter changes? I expect to mount and wire-in the ODR this evening after work (I don't have the paperwork with me at the moment, so I thought I'd ask for some advice). Any suggestions are greatly appreciated. It is there ODR unit I purchased.0 -
Jim
I would customize the settings for a reset curve in your geographical area. The factory gives generalized settings, but fine tuning really should be done.
I wouldn`t mess with the factory indirect settings much though.
Do you have the code access to do so?
Dave0 -
Thanks Dave, but
What settings should I use? Where do I locate the correct parameter settings for my area (Staten Island, NY)?0 -
Ok, sounds like a good idea.
But how do I e-mail you?0 -
Jim
Just click on print/archive, double click my email & your away.
It`s just that easy.
Dave0
- 167 Indoor-Air Quality
