A Question About Air Vents
FJL
FJL Member Posts: 354
And the opposite is true, correct? If the steam causes the float to close b/c of temperature while the pressure is low, the float will drop-away at some point, as the steam condenses and the radiator cools, and the process repeats itself so long as the pressure remains low. In this scenario, how much time can pass before the float drops because of low temp?
