hot water jackhammer
Mavster
Mavster Member Posts: 5
I have a domestic recirculating hot water system that jackhammers in a very strange way.
It only happens every few weeks, only in the morning, happens 5-15 times for a few seconds each with 10-60 seconds in between.
It does not appear to be the recirc pump and continues even when several taps - shower, sinks, etc are running.
Could it be the water supply coming into the house?
replies greatly appreciated.
  • Weezbo
    Weezbo Member Posts: 6,231
    sometimes an ST-12 will help
    by installing one in the cold water inlet side after the check valve .
  • Mavster
    yep - have an expansion tank
    Thanks for the reply, Weezbo.
    Yep, I have an expansion tank installed.
  • John Starcher_4
    John Starcher_4 Member Posts: 794
    Does it only happen when....
    ....you have a faucet open?
  • Mavster
    It appears to start when nothing is open and continues even when things are open including showers. It does not seem to match open or closed valves.
  • John Starcher_4
    OK, then....
    ...that rules out a faucet washer 'flapping' loose inside a valve. Is there a check valve in the recirc. line that might be chattering? To test, shut off your recirc pump and see if the noise stops.
  • Steamhead (in transit)
    Steamhead (in transit) Member Posts: 6,688
    Check your toilets
    for a slightly leaking flapper. Sometimes, the ballcock in the toilet tank sets up a standing wave oscillation that can sound like it's coming from everywhere and nowhere.
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,012
    Get a ...
    ... pressure gauge that reads up to 160 or 200 psi and put it on a bibb you can get to quickly. I once had to find the cause of a similar noise and it turned out to be the local water company pumping station. Pressure was falling to less than zero when their pressure pump shut down for a second or two. Without a gauge I'd still be looking in the house for the problem ;~) The water company didn't know they had a problem.
    Yours, Larry
  • eluv8
    eluv8 Member Posts: 173
    check valve
    sometimes if the flow is low, or just right the check valves can cause some funny sounds in the pipes. especially the swinging type.
  • Mavster
    thanks to all for the replies
    data I did not make clear....I can hear the jackhammer sounds in different places around the house....it moves around. in the pex piping....in the ceiling above a bedroom, near a bathroom, over a shower....
  • Mavster
    Data I did not make clear....I can hear the jackhammer sounds in different places around the house....it moves around. in the pex piping....in the ceiling above a bedroom, near a bathroom, over a shower....
  • Ed_26
    Ed_26 Member Posts: 284
    Jackhammer?
    Got a woodpecker in the attic or pounding on your walls/chimney? (had one once fell into my chimney!) :)
  • Bob Knebel
    Bob Knebel Member Posts: 26
    PEX Creepage?
    The original poster said ... "It only happens every few weeks, only in the morning, happens 5-15 times for a few seconds each with 10-60 seconds in between." AND "I can hear the jackhammer sounds in different places around the house....it moves around. in the pex piping....in the ceiling above a bedroom, near a bathroom, over a shower...."
    Just a guess here but maybe your recirc pump is timed to come on in the morning (after the hot-side PEX has cooled off at night) and then the PEX starts "creeping" with expansion after seeing the hot water. Did your plumber isolate the PEX lines well from the floor joists and wall framing?
