primary secondary w/ outdoor reset
Dan_33
Dan_33 Member Posts: 2
Installing three 84% eff. boilers and concerned when all zones call for heat and outdoor reset is set to low temperature supply that return water temp will be too low for boilers. Can you point me to a diagram that shows a primary secondary loop with the most effective way to control the return to an acceptable temperature for the boilers?
