NEED SOME DIRECTION!
Steve Garson_6
Member Posts: 35
Hot water or steam heat?
If water, do you have more than one circulator?
If one circulator, do you have zone valves or more than one thermostat?
CRANE SUNNYDAY 15
I HAVE NO HEAT IN THE BACK OF MY HOUSE, BUT THE FRONT OF THE HOUSE HAS NO PROBLEM GETTING HEAT. CAN THIS BE THAT I HAVE A BAD PUMP?0 -
IT IS HOT WATER. THERE ARE TWO CIRCULATORS. ONE FOR THE BACK OF THE HOUSE AND 1 FOR THE FRONT. I HAVE TWO THERMOSTATS!0 -
Jump the thermostat
Have you tried jumping the contacts on the thermostat to eliminate the possibility of a bad stat?0 -
THE PROBLEM TURNED OUT BEING OF ALL THINGS AIR. I HAD A TECH PURGE THE SYSTEM AND NOW WE ARE COOKIN. THANKS FOR THE SUGGESTIONS GUYS! COOL SITE! HELPFUL0
