NEED SOME DIRECTION!
Hot water or steam heat?
If water, do you have more than one circulator?
If one circulator, do you have zone valves or more than one thermostat?
  • HELPWANTED
    HELPWANTED Member Posts: 3
    CRANE SUNNYDAY 15
    I HAVE NO HEAT IN THE BACK OF MY HOUSE, BUT THE FRONT OF THE HOUSE HAS NO PROBLEM GETTING HEAT. CAN THIS BE THAT I HAVE A BAD PUMP?
  • HELPWANTED
    IT IS HOT WATER. THERE ARE TWO CIRCULATORS. ONE FOR THE BACK OF THE HOUSE AND 1 FOR THE FRONT. I HAVE TWO THERMOSTATS!
  • EMB
    EMB Member Posts: 37
    Jump the thermostat
    Have you tried jumping the contacts on the thermostat to eliminate the possibility of a bad stat?
  • HELPWANTED
    THE PROBLEM TURNED OUT BEING OF ALL THINGS AIR. I HAD A TECH PURGE THE SYSTEM AND NOW WE ARE COOKIN. THANKS FOR THE SUGGESTIONS GUYS! COOL SITE! HELPFUL
