Two stage thermostat
JackFre
Member Posts: 225
the Braeburn 5100 (2 stage heat/2 cool) or the heat pump model 5200 (2 heat/2 cool) www.braeburnonline.com
Does anyone know of a simple two stage thermostat
for heating and cooling other than the Tekmar
I have two seperate heat systems(floor warming-hydro air)
I was thinking a heatpump t-stat with electric heat
I don't know if this would work
Any help appreciated
Rich0 -
Isolated contacts would be .........
.....the key, but I have not found anyone other than Tekmar that offers this. If you use an isolating relay for the second stage, any two stage stat can be used. Pain in the ****......absolutely.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"There was an error rendering this rich post.
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
