Heat Exchanger Sizing
Joe Mattiello
Joe Mattiello Member Posts: 748
Try the Taco, X-pump block which has everything you need in 1 package. Please see attachment.
Joe Mattiello
Taco Comfort Solutions
  • Derek_7
    Derek_7 Member Posts: 1
    Heat exchanger sizing
    I am trying to get the right sized heat exchanger for 1000 sq feet of radiant floor heating. Supply heat would be 180F output heat should be around 100F (I think) and flow would be whatever a typical cartridge circ pump on a 1" supply would provide (10-20 GPM?).
    Thanks for any help anyone can offer.
    Big D
  • Brad White_9
    Brad White_9 Member Posts: 2,440
    Contact the manufacturers
    or suppliers. They should be able to give you what you need and specific to any conditions you may have. You are going to buy it from them after all... nothing we can say here would be that much better, IMHO....
  • Brad White_9
    An excellent
    suggestion indeed!
  • Jim_55
    Jim_55 Member Posts: 21
    can this be used to heat a small pool?
    Jim
  • Joe_58
    Joe_58 Member Posts: 4
    Unless this isn't the standard Taco TFP heat exchanger, the chlorine in the pool water would eat away the brazing in the heat exchanger.
