Taco iValve
Are the taco iValves open-close or actually modulated (open a little, open a lot)?
  • kpc_14
    kpc_14 Member Posts: 38
    they modulate...
    I have used the 3 way and curently have a 4way waitng to be used. I do like them a lot.
  • Dave Stroman
    Dave Stroman Member Posts: 765
    I use the 2 way. You can move much more Btu's with a 2 way than you can with a 3 way. We use them on high mass systems to protect the cast iron boilers.
    Dave Stroman
  • J.C.A._3
    J.C.A._3 Member Posts: 2,980
    i radiant valves....
    iradiant valves modulate.ESP is the open/close model and they look similar(fancy that!) but the ESP have black motors, while the iradiant 2-3-4 way valves are GREEN in color. Chris
  • Weezbo
    Weezbo Member Posts: 6,231
    the I series Valve from Taco,...
    are really great valves,the I series S is great for me as i have many oil fired boilers with indirects and multiple radiant zones using low water temps and medium water temps,..the I series S i use as a system by pass through the modulating set point control. The I series R 4 way is even better :) as it allows some very single minded low temp strategy with outdoor reset and an adjustable curve/temp ratio
    the I series R 3 way, can be dialed to change with input remotely, as a stand alone system . Just as easily as sending wires back to the boiler room, you can hydronically regulate available water temps at the station . they can be used to mix back up as well, so, in one sence it has multiple uses of the valve..... you could offer up grades to a heating system using bang boom temp(Zone valves) that had ESP or EBV actuators to either Setpoint or Reset ...as they are made in two way as well...
  • thanks everyone! seemed to good to be true for those "OR Only" type systems, but I guess we'll have to give them a try.
