Recognize these numbers anyone
eluv8
Member Posts: 173
Model V1130 PWR 14 OPT-00 Its a Hydronic vertical mount unit heater in a warehouse. No name plate Part number on the coil is 3M or H34304-2.
National
had a V series, but the numbers in my old catalogs skip 1130Retired and loving it.0 -
possible modine
Modine had a model V-1130 built between 53&78
2psi steam capacity was 271,200 btu0 -
that was quick
I contacted modine as that was our first thought. They said not theirs, With this info I will call back and see if they can check again with those years.
On edit: Records back then at modine arn't great i guess they dont have anything on it. Thanks bert I think your right on with your thinking at least I know about what size it is now for replacement.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
