Parts for Stelrad Group Boilers
Leo
Member Posts: 772
If I'm not mistaken they are gone. I worked for a company that had one in the customer base with an OEM side mounted tankless coil. We abandoned it and installed an indirect. Depending on how serious your problem is it may need replacing. In our case we were able to substitute a part with something readily available.
Good Luck,
Leo
Good Luck,
Leo
Where can I buy parts for Stelrad Group boiler in the New England area?0 -
Stelrad Boilers
Stelrad boiler can found in Canada check out on the web0 -
Wow
I checked the web, what's listed is totally different from the oil fired one of the 80's that I was thinking of.
Leo0 -
I looked around on the web only found them in the UK, these boilers found their way here somehow, must be a local Rep?0
- 87K THE MAIN WALL
- 112 Chimneys & Flues
- 106 Geothermal
- 979 Plumbing
- 387 Solar
