Prepping hardwood for radiant floors
Wayco Wayne_2
Wayco Wayne_2 Member Posts: 2,479
it's common knowledge to have it sit in the space where it will be installed and let it adapt to the temperature and humidity levels. When asked I always say 2 weeks wait before installing the floor. I'm at odds with a GC who says 3 days is enough. I know it isnt. How long do you guys recommend? WW
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=255&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • wood issue
    As a former woodworker- there is no right answer to this question. It depends on the condition of the wood and interior of the home. You need to be sure the space has stabilized - no more drywall compound drying... The best way is to find the ideal moisture content of the wood specie ( from the manufacturer) and use a moisture meter to check the flooring.
  • kevin coppinger_15
    kevin coppinger_15 Member Posts: 35
    wayne..
    if he says 3 days is fine get it from him in writtihg that ifhtere are issues that it is his problem.
  • Dave Holdorf_2
    Dave Holdorf_2 Member Posts: 30
    Moisture Meter
    WW-
    it can be anywhere from 3 days to 2 weeks, it depends upon the relative humidty of the season and of the space itself.
    It always comes down to the moisture content of the wood. Ask the wood floor installer if he has one of these tools, if not, may not be a bad investment for your self for future work.
    here's the link http://www.grainger.com/Grainger/items/1UKE2
    hot_rod Member Posts: 26,579
    Also depends on where the wood comes from
    if the wood was stored in a dry clomate, like Arizona, then taken to a humid area it will actually take on moisture not lose it.
    I remember Mickey Moore of the Oak flooring Association telling me about a job in costal Maine that took on so much moisture it pushed the bottom wall sill plate right off the floor as the wood expanded!
    hr
  • Couderay
    Couderay Member Posts: 314
    Wood floors
    After talking to a few hardwood installers three days was good enough. House was at 68 degrees and the wood was out of the box and seperated, installed 3 days after being seperated.
  • Wayco Wayne_2
    Thanks for the replys
    I will try to get this info to the homeowner so she won't worry. WW
